Rear Brake pads
Rear Brake pads
Im pretty sure these will fit but can someone back that up?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
anyone also know where I can get a fitting kit from? the pins and sliders etc...
Re: Rear Brake pads
i know halfrauds used to do them but any local motor factor should have em
Re: Rear Brake pads
they will fit, but why bother with them expensive ones, there are cheaper ones out there
Re: Rear Brake pads
Same as what I have on the front and they've lasted ages and work goos enough...
Ill check out my local motor factors for the kit...
Re: Rear Brake pads
you the rear brakes are there simply to stop the car spinning while braking, think its about 15% of the braking efficiency is to the rear, so any pad will do really ...the front is the place to spend the money
Re: Rear Brake pads
Ive got a set of pads and the fitting kit on order form my local motor factors for about £15 plus vat, picking up tomorrow... will use the savings towards other bits im after...
Users browsing this forum: No registered users and 70 guests
