Rear shock mount diagram please :)
by MadOnVaux! » Mon Jan 02, 2012 1:09 pm
Could someone please post a diagram of the rear shock absorber top mounting on a Calibra please?
I just need to see what parts should be there and in what order.
Ive had a rattly knocking on mine ever since new rear shocks were fitted and i replaced the spacer sleeves yesterday and when i dropped the shocks down, I found a shaped washer sat at each side at the top of the shocks, inbetween the shock and the lower rubber top mount, which i dont think should be there, and i reckon that is causing the noise.....hence why i need to see what should be there and where it is supposed to be.
Massive thanks in advance :)
Re: Rear shock mount diagram please :)
by Mark1 » Mon Jan 02, 2012 2:04 pm
by MadOnVaux! » Mon Jan 02, 2012 5:25 pm
Cheers Mark :)
Although it's abit of a bugger, as it appears the washer thing that i thought shouldn't be there, apparently should be.....so now i have no idea at all what is causing the knocking :(
Users browsing this forum: No registered users and 67 guests
