4x4 rear hub
4x4 rear hub
by drsswift » Sun Jul 01, 2012 5:00 pm
local garage managed to destroy my rear hubs. Cant manage to find replacements any where. read somewhere that the 2 ltr omega ones fit. Is this true?
Re: 4x4 rear hub
by Callyman » Sun Jul 01, 2012 5:11 pm
If you mean the inner part that the Drive shaft bolts to then yes they are both Part 90497687
Item 11 on here http://www.opeloem.com/vauxhall/calibra ... pivot.html
Re: 4x4 rear hub
by Allys Cally » Sun Jul 01, 2012 5:13 pm
Re: 4x4 rear hub
by MadOnVaux! » Mon Jul 02, 2012 2:58 pm
drsswift wrote:local garage managed to destroy my rear hubs
I hope they are paying!!
Re: 4x4 rear hub
by v6 steve » Mon Jul 02, 2012 6:18 pm
where did it happen ? i got a call today from a garage asking me if i had one as the broke one, a v6 one is the same you could use a 4 stud one but your going to need to use a different wheel
Re: 4x4 rear hub
by drsswift » Sun Jul 15, 2012 5:01 pm
got given the wrong wheel bolts. went in fone. the when it came round to changing a tyre found out that all he threads on all four hubs were stripped. Cant use the rear hubs off a front wheel drive already tried it. And tried three different omega hubs. they dont fit either
Re: 4x4 rear hub
by bennymac » Sun Jul 15, 2012 8:43 pm
i have an old subframe at home that I can check for you i'm sure i have a hub that had a wee bit of damage to the threads but they cleaned up ok.
you can have it for the postage costs buddy if you still need one ?
