Best 8v Brake upgrade?
Cheerleader Toss
by Novaneil » Wed Dec 22, 2004 2:05 pm
Hi,
I have an 8v SE5 Cally and want to up the braking (as it is crap at moment!!!)
I have about £250 to spend... Whats do you recommend?
I have found some V6 Calipers from V-Tuning for £200 with plain 288mm discs.... is this going to massively help my braking? (Its 4 stud by the way, which is what my car is)
Neil
Novaneil
by SukySaggi » Wed Dec 22, 2004 3:23 pm
Do you still have the original brake pipes. Change them to braided ones, front and rear, get some black diamond front discs, standard pads and renew your brake fluid. You should notice a big improvement. :thumb:
SukySaggi
by Enigmatic » Wed Dec 22, 2004 5:51 pm
yeah i opted for the braided pipes upgraded to green stuff pads, and cross drilled discs made a vast improvment as before id brake on a drain cover and id still be in motion
felt like acunt
Enigmatic
by Mark1 » Wed Dec 22, 2004 10:30 pm
Have a look at LMF as they do an upgrade to V6 brakes for about £200 and it fits 4 stud hub's.
RE: Oil pressure sender stuff - Yep I
by AndiSe5 » Wed Dec 22, 2004 11:47 pm
Id say LMF
I got 308mm on my cally with braided hoses.
So as u should guess i can stop pretty quick...
AndiSe5
RE: Wot are the fronts like to change?
by Enigmatic » Fri Jan 07, 2005 4:38 am
andi id like a look at ur car kiddo looks mean!
Enigmatic
