Camber kit
by Vid » Tue Jan 11, 2005 2:09 pm
Ok, had a closer look at this kit and it actually says in the description:
"these kits do away with excessive inner tire wear that is common on the std opel/ holden set up"
and in the description for the same kit for a different car it says:
"THIS kit is for your VR VS with independant suspension and the VT VX AND VY that is with out lowered or the fe2 suspension".
This leads me to believe that it would not adjust sufficiently enough on a lowered car!!
But then again, I maybe wrong.
Vid
RE: Re: RE: 12 volt to 10 volt DC/DC
by 16vastra » Sat Jan 15, 2005 1:20 pm
well i do these eccentric bushes, made by powerflex. judging by a thread on mig the best way to do it is to buy 4 eccentric bushes to fit to the trailing arms for maximum adjustment.
CC price (works out at just over 10% discount on these parts) for all 4 would be 90 quid posted. they take 4-5 days to make as they are a special order.
for those lowered up to 25mm just the 2 rear eccentric bushes would be fine at 45 quid posted.
16vastra
RE: what the heck is this light for???
by Vid » Tue Jan 18, 2005 12:21 am
Do these bushes allow for any adjustment or are they fixed mate??
Vid
by 16vastra » Tue Jan 18, 2005 2:53 pm
yes. eccentric for adjustment mate, position them to make the rear irs sit at different angle
16vastra
