Which pads are best?
by sinbrad » Sun Mar 19, 2006 12:08 pm
Not quite upto the rallying stage as yet. Will be looking at something a bit more for the daily use as you suggest, just a bit daunting trying to get the correct one's
by Toddy » Sun Mar 19, 2006 2:01 pm
Smurf, do you do track ays? Only asking as I thought red stuff ones were not very good for road use (need to get them well warmed up).
Toddy
by dicky » Sun Mar 19, 2006 2:28 pm
I had greenstuff on my old 8V cally and they were very good indeed. No brake fade and very grippy. Only downfall with i could find was ther wernt good if cold. I got them from my local Motor Factors for £50.
dicky
by dj_smurph » Sun Mar 19, 2006 4:38 pm
eventually going to do track days that is why i said for the future(should have said) because by the time i get round to replacing the pads the engine should be sorted
dj_smurph
by GAZA62 » Sun Mar 19, 2006 9:25 pm
As said above Greenstuff are OK when warmed up but be carefull when starting out as i found out a few years ago.They give very little dust which is great for me driving an Auto.They are very noisy with the Turbo Grooved discs and take a while to quieten down sounds like a criket when you brake.
I it was not for bad luck i'd have no luck at all
Users browsing this forum: Majestic-12 [Bot] and 15 guests
