Lowered cally opinions please
thats about the same ride height i've got on mine with 40mm springs and standard shocks, as baz says it looks like a 60mm drop on the front not 40mm
I've got my Calibra(16V Ecotec) lowered a couple of months ago on Eibach springs(35-40mm) & Bilstein shocks and it looked same as yours. After a while it setttled - the front stayed the same, back dropped a little bit. I'll post a picture later on. Also you can turn the rear springs around the base, to see if it makes any difference.
Consult the manual time:
All are the same height, turbo has higher ground clearance.
the older calibras up to 93 did sit higher than the later ones i have checked my older manual and this is what it say
calibra calibra4x4 calibraturbo 4x4
126/5.0 131/5.2 120/4.7 road clearance
exhaust exhaust floorpan position on vehicle
so there is a height differance between the younger and older calibras so the redtop sits higher than the ecotec and the older turbos were lower than the8v and the 16v's
tazz666
