abs
Having a rusty brake line won't cause the ABS light to come on.
When the ABS kicks in the pedal drops as you describe. If the sensors or any of the trigger wheels are damaged the system can get confused and kick in momentarily at the wrong time, like under normal breaking.
Read the codes, it's the only way to find the fault. Other than randomly guessing at parts and replacing them.
Read www.topbuzz.co.uk the tech info section, and reading ABS codes.
