Jacking/axle stand points - Haynes picture doesn't match car
Re: Jacking/axle stand points - Haynes picture doesn't match car
by Fraz » Fri Aug 14, 2009 10:27 pm
leave old front pad in, hold calliper (or put bolts back on) insert large type lever between piston and disc, apply pressure to piston
oh an remove brake reservoir cap
thats what I do
by bodgetastic » Sat Aug 15, 2009 12:30 am
I usually jack up on the subframe and insert axel stands where you have located them or the other way round. Usually take out the pads and push the piston in with a bar but take off reservior cap first
by Robs-se » Sat Aug 15, 2009 11:25 pm
Use a large flat bladed screw driver on the edge of the cylinder and take the resevoir cap off as well
