se9 abs problems
Re: se9 abs problems
k1nty wrote:sounds exactly same as mine.i replaced the controller as it seemed to point towards itself.and mine is a1 now.
ok, I'll try to have look at it this weekend & get one from ebay. We'll see if it cures the fault.
Thanks for the advice mate.Re: se9 abs problems
Right, double checked my sensors & ABS rings this Saturday & found a wee crack in one of the front ones. cleaned it with wire brush & the crack widened, so need a new ABS ring. I think that will definately cure the fault, so try to get a new ring or replacement CV joint
Thanks for your help, mate
by the time you remove joint and boot,may aswell fit a new joint .around 25 quid.
k1nty
Well fitted new ring to the CV joint in about 20mins & problem solved. happy days!! Thanks for the replies k1nty
Users browsing this forum: No registered users and 91 guests
