Which Suspension
yeah i saw the kit listed, but it doesnt say its 2 of each, above on the ajustble single units it says 4 per car.. which.. is kinda true.. you do need 4 of that size bush, but just to ajust the camber back into spec i dont know if you should have both.
I'm just fitting them into the inner for now, kelly has the gmac so both ajustable which seemed to work, i will get a camber printout of the new cally when its all installed just to see.
