Camber Bushes Fitting
Fostersice17
basically i did it in my own garage. if you have a large vice its fairly easy but does require two peeps.
basically tools are
stanley knife
a large socket that is as wide as the metal edge where the bush is
a small socket.
i bascially cut both ends off the bush. so you can see the metal lip. and use the large socket to push the bush into. and the smaller one pushes the bush basically inside a vice.
basically tools are
stanley knife
a small socket.
KRIS_537
