Have i got the right 'washer' on here?
Re: Have i got the right 'washer' on here?
it does locate into the bottom arm but apart from the actual bush in the shock nothing else
MadOnVaux! wrote:How is the shock mounted at the bottom?...is it just a bolt that mounts it through the lower rubber mount on the shock or is there some other bushes etc there?
There is a lug on the bottom of the shock which should locate into the arm then a bolt goes in and holds together
Cheers Steve....I think i'll get a couple of new lower mount bolts too.
I'm clutching at straws i know, but i cant think of what else to do!!
Does anyone know if Bilstein B4 (Black) rear shocks should use the same mounts as standard or do they come with their own?....I'm just wondering if this could be anything to do with it?
I really am tearing my hair out over this now!!!
yes its a direct replacment, I have B4 on mine and have fitted new standard top mount rubbers and the bottom part fits right into the apature on the bottom
Fraz wrote:yes its a direct replacment, I have B4 on mine and have fitted new standard top mount rubbers and the bottom part fits right into the apature on the bottom
Thanks Fraz
Back to the drawing board time.....jesus this is doing my head in, you'd think a knocking would be simple to sort, this just seems like it hasnt got a cause
