Steering problem please help
I get a funny noise every now and then from the power steering, the sort of noise you get if you get to the end of the steering travel. I have recently had the pas fluid changed and wonder if i could be because there is air in the system?If not could it be a noisy pump only does it now and then every couple of minutes or so. Could it be anything else?
gremlin
