ABS code 56
ABS code 56
Went to a friends to check over his car so he can sell it.
He has a 'N' plated ecotec with the abs light on
done the paper clip test and got these results :-
12 test mode
41 n/s front sensor (no surprise there)
56 ?????
12 test mode
I'm sure i've done it right but what the hell is 56 all about - done a search on here to not avail. It's also not listed on topbuzz's site [img]/sad.gif[/img]
how much is a new sensor BTW ?
12 test mode
56 ?????
12 test mode
sofaman
Bizzare.. but once the other ones sorted, i'd not worry about it unless the light stays on.
The only reason i asked is because i know it can be confusing to keep count sometimes, and the spacers between codes arnt that much more than between code-parts..
the only "6" are
16 LH Front Solenoid ( Relay & Connections )
46 RH Rear Speed Sensor ( Air Gap & Operation )
So if you're 100% certain you didnt get confused and mark the first part of one code as the end of another etc etc... then I can only suggest to replace the sensor and try it, they're about 50-60quid from vauxhall but i dont know if they're on the parts discound for club any cheaper, or if autovaux do them any cheaper?
the only "6" are
