Does Your Wheel Sit Centred?
The correct way to remove an airbag is to first disconnect the car battery, then wait at least 60 seconds for the capacitors in the system to discharge. You can then safely remove the airbag without fear of it going off (unless you drop it on the floor from a reasonable height of course). Once refitted securely, reconnect the battery and hey presto - airbag off & on without bringing the warning light on (or injuring yourself).
SteveU
SteveU
Cheers Steve - I put an airbag wheel on my 8v when I first bought that (the previous owner had put a MOMO one on and I wasn't keen on it). I'll get the tracking and balancing sorted out ASAP and if that all fails then will re-align the wheel most probably.
Col - I know what you mean about them being busy - that place is always packed isn't it?! I think I'll have to stay over at my girlfriend's one night (she lives in Micheldever village), then drive over there for 30 minutes before opening time and be the first in the queue!
Smurf
