5 Stud Conversion
5 Stud Conversion
by LE16 » Tue May 17, 2005 7:12 pm
Hi,
Anyone done a five stud conversion? Im doing it to my SE5 and need to know how the rear hubs will be set up. The problem is the donor car (my LE 4x4) has the abs teeth on the inner cv joints and they need to be on the outside as on the SE5. I'm not transplanting that heavy diff just for poxy abs to work but am wondering if once the outer joint is removed off the 4x4 hub, will I be able to fit the abs teeth from the se5. The sensor is mounted on the caliper on the SE5.
Any Idea's?
Sean
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
by Monkey » Tue May 17, 2005 7:59 pm
You could use the rear hubs from a V6.
Monkey
by LE16 » Wed May 18, 2005 12:34 am
Thats another idea, but i dont fancy buying them new. I'll look at that if it needs to be done once I have got them apart and in my hands.
Sean
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
