Won't Tickover ! !
Won't Tickover ! !
by stevemrose » Wed Jun 01, 2005 9:19 pm
How annoying,car starts and ticks over fine when cold,but when it's hot it's harder to start and wont tickover.Any ideas? PLEASE.
stevemrose
by jayl645 » Thu Jul 07, 2005 11:05 pm
have u tryed taking the idle control valve off and give it a goos soak in carb cleaner(use about half a can),it worked wonders for my 8v,
jayl645
by Johnnytenpints » Thu Jul 07, 2005 11:33 pm
Could be your fuel pump relay or coolant temperature sensor.
When u say it's hot do you mean after the engine has been running or just the outside temperature?
Johnnytenpints
by TommyC » Fri Jul 08, 2005 11:14 am
Steve, you might wanna run a search on the forum for other threads about idling probs there's loads of them. You'll probably be able to sort your out from just reading all the others.......
TommyC
Users browsing this forum: Google [Bot] and 11 guests
