camber seems well out
by joeraz » Wed Jun 22, 2005 5:24 pm
following on from the thread below
<a href="http://www.clubcalibra.net/forum/showthread.php?t=13124" target="_blank">http://www.clubcalibra.net/forum/showthread.php?t=13124</a>
i went along to a tyre fitters to get my N/S/R swapped for the O/S/F
i new there was a bit of inside wear as advised by vauxhall 2 weeks ago (slight wear) was what i was told,,
well
the tyre fitters today said they would not change the tyre as it was far too worn,,. he was right, it had went right down on the inside edge, about 1 inch of the tyres bald..
so i`m gona have to fit my spare as it is of similar tread wear but,,
my cars on standard shocks but its sitting well out,,, 1st time i had really noticed it,, can the rear camber be adjusted..????????
i`m guessing its the 17" wheels that have changed the footing,,, but i dont really know why!
HHHHHEEEEEEEEELLLLLLLLLLLPPPPPPPPPPPPPPPPPPPPPPPPPPP!!!!!!!!!!!!!!!!
LOL
joeraz
by ROG » Wed Jun 22, 2005 6:13 pm
you need a camber correction kit for the rear if its lowered toadjust the camber,
The inside edge of the back tyres will wear more , as you accelerate hard the rear of the car drops as the car does a wheelie (mine does anyway!), as the car drops at the rear the tyres wear on the inside edges due to the increased camber when pushed down by the acceleration
ROG
by joeraz » Wed Jun 22, 2005 6:47 pm
it aint lowered but still the camber is fooked,,, were do you buy a camber adjust kit from.???
cheers
joeraz
by King Calibra » Wed Jun 22, 2005 6:56 pm
<!--QuoteBegin-joeraz+--><div class='quotetop'>(joeraz)</div><div class='quotemain'><!--QuoteEBegin-->it aint lowered but still the camber is fooked,,, were do you buy a camber adjust kit from.???
cheers<!--QuoteEnd--></div><!--QuoteEEnd-->
eBay? Seems to have everything else....
King Calibra
by joeraz » Wed Jun 22, 2005 7:00 pm
this is written on the wheel
7j x 17H2
1 p x
MADE IN S. A.
H1202
THEN ON INSIDE RIM
1770N355110P72
35066
150898
0117
ET35PCD110TE156
I THINK I SEE THE PROBLEM
joeraz
by Stupink » Wed Jun 22, 2005 7:46 pm
have you had the camber measured? the et won't throw the camber out THAT much, if its out that much then you either have saggy old springs, or snapped springs, or it IS lowered.. a lot of springs will look standard after a few years of grime etc.. eibach etc look standard out the box near enough.. they're grey not bright pink etc lol..
get the camber measured first, see how bad it is.
by joeraz » Wed Jun 22, 2005 8:04 pm
this cant be lowered,, seems too high,, could be busted tho.
measuring the camber,,, is that just to see if it is out,, is it like a wheel alinement
joeraz
by jayl645 » Wed Jun 22, 2005 9:57 pm
drives a p11 soon,?
is that a nissan primera p11 1996>,
i had a p10 nice motors but parts are silly prices,and drivers side drive shafts are a common prob,they snap very easy,i went through 2 in 2 years,
jayl645
by daddycool » Wed Jun 22, 2005 9:59 pm
Your car looks standard height to me.
Which tyre was bald?
My car eats the inside edge of the front tyres [img]/sad.gif[/img] But if I rotate them religously every 3k then they last about 24 months [img]/smile.gif[/img]
daddycool
by Stupink » Wed Jun 22, 2005 10:18 pm
Agreed that looks standard height..
Did you put the tyres on? or could they have been worn on a different car even?
get a picture from the rear of the camber, but yes get them measured, is like wheel alignment only they do a full geometry to get camber as well as toe etc on all 4 wheels. this way you should eb able to see why they've worn. it's not solely the wheels imo.
by LETMania » Sat Jun 25, 2005 11:25 am
your bushes in the trailing arm is probably the cause, a b***h to replace, but the parts are cheap about 8 quid per bush and you need 4 of them.
LETMania
by damon » Wed Jul 20, 2005 1:00 pm
So any ol' Camber Correction Kit will do 'eh? Provided its for a calibra ofcorse..[img]/smile.gif[/img]
Or can someone recommend a good one?
damon
by thecrow » Sat Aug 13, 2005 8:47 pm
Those numbers have et35 in there - meaning the offset is et35 - that's waaay too far out. You need et42-49.
The reason that they're wearing is that because your wheels are sitting out further than they should be, that compunds the effects on the camber.
There are machine shops that will shave down the contact face of the wheel by Xmm to get the offset right. Look for "precision engineers" on yell.com and one near you will do it - the place near me charges £30 for 4 wheels so its well worth it for the money.
Apart from the offset being wrong, you should really be ok with camber (until you lower it). The only real way to solve it is to get an adjustable camber kit (about £180 IIRC) and get it set up properly, but you only NEED to do that once its lowered.
Like I say, get the offset right, and your wear will be even once more [img]/wink.gif[/img]
Hope that helps.
thecrow
by joeraz » Sat Aug 13, 2005 10:45 pm
payed £99 today for a camber correction kit, but only got 2 bushes? :confused:
joeraz
by Fraz » Sat Aug 13, 2005 10:55 pm
dont know how many bushes I got as Gavin at wallace fitted mine ...but these where the fixed ones not the adjustable ones
I think the ones that go in the outer part of the rear arm (they are just at the rear sill where it ends) have four, where as teh one sI had fitted which are the inner ones are only two
If that makes sense
