Changing the PAS pump on a Turbo
Changing the PAS pump on air-con Turbo
by steve3000 » Sat Jul 02, 2005 11:05 pm
Ok, exactly how difficult is this?
Just been down to the breakers this morning and picked up a pump off shelf for a fiver... then took a look under the bonnet and realised it's not so easy to do the swap.
So do I have to take the turbo/manifold off to do this? can't see any other way to get at them mounting bolts???
...and I thought the V6 alternator was tricky! :roll:
Steve
(it's got air-con btw, so the pas pump is at the top of the engine, with the mounting bolts backing onto the manifold... [img]/sad.gif[/img] )
