brakes
brakes
by base56 » Wed Jul 06, 2005 9:27 pm
as I have the cali in the v6 automatic flavour, the brake discs and pads tend to take a bit of a battering. I'm thinking of uprating the fronts for some drilled/grooved versions but afer some advice..
should I go drilled or grooved or drilled and grooved??? I know what the main points are but just after some opinions of people who have used any of the above?
base56
by Fraz » Wed Jul 06, 2005 9:43 pm
had the drilled groved ones on teh car for about 3 months ...then just fitted the drilled ones
Hated the noise when braking and the feel through the pedel, drilled ones are ok but they do tend to have small cracks around the drilled hole....should be counter sunk
by plank "o da& » Wed Jul 06, 2005 9:58 pm
i have fitted ebc drilled and grooved, with green stuff pads, although noisy and the feel through the pedal is wierd to start with...they do stop me...very well, just got to fit braided hoses now, then it's on to the rears
plank "o da&
