Help needed with lowering - are Gmax OK??
Hi,
I'm ready to lower my motor, have been doing a bit of searching around and have found a Gmax full kit -40mm drop (springs and shockers) brand new for £160 + £20 P&P. I've done a bit of searching on forums and found mixed views on the Gmax stuff, some have got on great with it, others haven't.
As much as I would like to I haven't got the £££ to spend on the the top quality stuff, I was considering just getting Eibach springs and leaving the standard shockers but the Gmax kit is not that much more expensive and its a full kit.
Can anybody help me out and give me any advice to help me make up my mind - to Gmax or not to Gmax? All I'm armed with at the moment to lower my car with is a couple of hundred quid!
dazjb
ive used g-max springs on my old car and i wouldn't buy them again,the ride felt quite unstable and very hard,if i was u i would get a 2nd had decent set,not a realy old 2nd hand set but quite a new 2nd hand set if that makes sense,keep youe eyes open they do come around,
but then again i had them in my standard shocks!!!,
im sure others will put there likes and dislikes up soon,
cheers jay
cheers jay
jayl645
Peruzzi
Thanks for all your comments. Yep, thats the mixed response i've been reading about ... hmmm!!
Back to square one ... i'm stuck between getting the full Gmax setup or just going for the Eibach springs, I thought it would be a good idea to get the full kit with shockers (even if it is Gmax) as the shocks on a 12 year old car are probably very worn anyway! :confused:
dazjb
Users browsing this forum: No registered users and 81 guests
