Tires wear
Tires wear
Rear tiers wears out inside , got Camber kit , lowered 40 , 215/35/19 is expencive
What to do ? anyone ?
O2re
Wallace do an adjustable kit or you can by fixed Irmscher correctors from your local Vx dealer.
Or you could do a SEARCH for Fatladz DIY solution [img]/smile.gif[/img]
There, I've done it for you [img]/smile.gif[/img] <a href="http://www.clubcalibra.net/forum/articles.php?action=viewarticle&artid=25" target="_blank">http://www.clubcalibra.net/forum/articles....rticle&artid=25</a>
daddycool
<!--QuoteBegin-daddycool+--><div class='quotetop'>(daddycool)</div><div class='quotemain'><!--QuoteEBegin-->I presume from your previous posts/pics that the car has been jigged!
Did they do it correctly?
Get the camber/toe/etc checked and then take it from there.<!--QuoteEnd--></div><!--QuoteEEnd-->
Yes jigged , done it my self ,so it`s good as new
Camber kit did i buy "down under" (Astralia)
can adjust alot but not enought in correct direction
i guess the only way is to rebuild rear frame
if i find a solution i`ll post it
thanks to everybody posting , nice to get some comfort
meantime i`ll have to spend all my $on tiers
O2re
<!--QuoteBegin-daddycool+--><div class='quotetop'>(daddycool)</div><div class='quotemain'><!--QuoteEBegin-->Did you follow the link I posted earlier in the thread?<!--QuoteEnd--></div><!--QuoteEEnd-->
Yes , i maybe want to cut off and move the plates , instead of just drilling a new hole , i`v got a 60mm drop , don`t know if this mod is enough
but i think so , because i also have camber kit
i see you run on 19"`s , any prob. ? your wheel ali.... measure figures?(bad language sorry)
any calibra`s on airbags around ? guess this is moore common on the Cadillac catera (same rear frame)
O2re
