Caliper
Caliper
Hi
I have a '95 ecotec and I took her to a "free all over check" at a vauxhall dealership.
Upon this check I had a few problems highlighted and she is not actually in that bad a condition !! In fact considering the price I get her, 12 owners (inc me) and no history she is in excellent condition.
Anyway, the drivers side rear wheel squeeking and also it doesn't actually look like it is gripping the disk. Also once I have pressed the brake and pulled away it feels like it is a bit sticky. Would a brake bleed be a good place to start or is a new caliper in order ?
Any pointers appreciated.
Craig
Craig
cchapman191
my calibra failed the mot last month because of this craig, 'low effort on rear near side brakes'
My caliper had seized up, so I needed that overhauled, and the 2 rear brakes valves had to be replaced as contaminated brake fluid had caused corrosion [img]/sad.gif[/img]
that was £210 for all that. the valves (which in my invoice said 'Brake Regulator Modulator') cost £90.
apparently a common problem? hope this helps
Iva Biggen
