Squeeky squeeky !
Squeeky squeeky !
Can someone please tell me how the hell to stop my breaks from screeching.
I too it to Vauxhall who said the pads are good and the disks are fine.
The damn thing are embarrassing !
Thnaks
Thnaks
cchapman191
take the front callipers off and take the pads out you will see two lugs at the top and two at the bottom put a smear round the top and bottom then if you look at the back of the pad you will see in the middle a prong type thing not sure on its name put some on that aswell and dab a bit on the back of the pad do this for all the pads but whatever you do DONT for god sake get any on the front of the pad or the disc it will result in having no brakes you could also put some on the retaining clip but just the ends then after all is done you will need to bleed i will be very suprised the vauxhall didnt pick up on it but hey thats vaux for you
wilza0
