Best camber correction.
Here in Australia, Calibra's are very rare. So needless to say, Camber Correction Kits are even more so.
I was wondering if a kit was absolutely nessercary or if I take my car to a suspension place they can fix the camber angle without one.
Or do I have to buy one and take it to them to install for me? (I have no tools or know-how. First car!
If i buy one im gona have to get one from ebay or somthing I think.. are they all the same? or is there a good one in paticular i should look for?
Thanks!!!!!!!!
Thanks!!!!!!!!
damon
with a V6 if you can put up with the rate it eats tyres, then there is not a need to fit the corrector kit... I wouldn't know how bad it gets because I put ajusters on mine when fitting the lowering kit.
Give it a try for a set of tyres and see how it goes.. if you can get them flipped/rotated on the rims cheaply then it might not be too bad.
