top mounts question?
lowerd my cally 30mm today wow what a fun job but noticed there seems to be a small gap around the rubber mounts is this normall cause i have lowerd or is it somthing i have done wrong everthing seems tight used all the old nuts just not sure if it were like that before???????
wilza0
rog its more like there is a big nut which holds the spring in place quite thick then the metal plate with rubber round it which is under the bonnet is sat ontop of that nut and there is a gap do i just need to change the size of the nut i will take a pic and put it on here so you can see what i mean
wilza0
jayl645
wilza0
jayl645
wilza0
