Track rod ends
Track rod ends
After putting new 17" wheels on decided the tracking was out but when i took to tyre shop they tell me the trackrod ends are completely seized.
What a bummer its one thing after another with Calibra's.
Anyway does anyone know if its a big job or what?
Could it be done or does it need to go to proper garage?
chas27
when i went for tracking they said that mine were siezed, without touching them, they needed replacing!
The next day i soaked them in wd40 a few fimes, left it till the next day and cleaned them up with a cloth, then went somewere else and because they looked recently fitted they just did the tracking woth no problems
ROG
the main problem is the actual 13mm locking bolts on the track rod ends will snap off. I tried to loosen mine of and one broke. I just replace both sides
easier if you remove both the arms from the actual rack and then have them in a vice, It took me about two hours from start to finish to do both sides
Users browsing this forum: No registered users and 92 guests
