How low should i go?
Hi peeps!I've bought a set of 18's for my calibra v6, they do look mighty good, but the standard suspension makes it look like a land rover, so needs to be dropped a bit, how low can i go? i'm looking at a -30mm setup, will this foul the arches?
JAYV6
JAYV6
<!--QuoteBegin-JAYV6+--><div class='quotetop'>(JAYV6)</div><div class='quotemain'><!--QuoteEBegin-->50mm!!!, did that not scrape?<!--QuoteEnd--></div><!--QuoteEEnd-->It's still the same suspension set up with the 19s and they don't scrape either.
Rear arches didn't need any mods at all, but front needed quite a bit of work.
daddycool
<!--QuoteBegin-daddycool+--><div class='quotetop'>(daddycool)</div><div class='quotemain'><!--QuoteEBegin-->Tramlining is normally caused by the wrong offset wheel.
What offset you got?<!--QuoteEnd--></div><!--QuoteEEnd-->
That is one of the factors, but wide tyres are the most common factor. On Calibra's anything over a 215 width tends to tramline, as the sheer width of the thing makes it follow the contours on the road.
<!--QuoteBegin-CalibraTurbo99+--><div class='quotetop'>(CalibraTurbo99)</div><div class='quotemain'><!--QuoteEBegin-->That is one of the factors, but wide tyres are the most common factor.<!--QuoteEnd--></div><!--QuoteEEnd-->
Offset is THE main factor. Wider tyres only amplify the problem.
Incorrect steering geometry is another cause.
daddycool
<!--QuoteBegin-daddycool+--><div class='quotetop'>(daddycool)</div><div class='quotemain'><!--QuoteEBegin-->Offset is THE main factor. Wider tyres only amplify the problem.
Incorrect steering geometry is another cause.<!--QuoteEnd--></div><!--QuoteEEnd-->
Incorrect steering geometry? In what way? Track rod ends??? I presume you mean incorrect suspension geometry but that would simply mean bad roadholding full stop, and pulling under braking. Tramlining is completely different, predominantly caused by wide wheels wanting to follow the flattest route along the road.
I'd say that a higher offset would simply push the wheels/tyres away from the centre line of the vehicle which wouldn't change the contact area of the tyres in any way at all. In fact, higher offsets are generally better for handling as they increase the track of the vehicle... the only reason we don't all do it is because of MOT failure for protruding wheels, and fouling on arches.
