Tyres for standard 16" turbo wheels
by joeraz » Sat Aug 06, 2005 11:00 pm
Im after 5 new non-directional tyres for the turbo fan wheels but cant make up my mind what kind to get quotes for:
the currant tyre size is 205/50/16 W rating, is this the standard size?
i currantly have marshals on the wheels which i can tell u are good allrounders but very crap on snow (most are **** on snow)
Which would be a good deal?
function add_P1132(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P1132')){coreFrame.load_add(d,type,'P1132','205/50VR16 ECONOMY RADIAL','1.00','2055016VR','0',0,'TD2,TD3','EC','','','EC',opt,sf,s,'');}else{setTimeout('add_P1132();',500);}}205/50VR16 ECONOMY RADIAL
</b>
2055016VR
£39.00dw(qandi(['P1132','0.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P1132()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P1132()</a><a href="http://java%20script:add_P1132(1)" target="_blank">java script:add_P1132(1)</a>
function add_P3121(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P3121')){coreFrame.load_add(d,type,'P3121','205/50VR16 NANKANG NS2','1.00','2055016VR','0',0,'TD2,TD3','NS2','','','NA',opt,sf,s,'');}else{setTimeout('add_P3121();',500);}}<b>205/50VR16 NANKANG NS2
</b>
2055016VR
£40.00dw(qandi(['P3121','0.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P3121()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P3121()</a><a href="http://java%20script:add_P3121(1)" target="_blank">java script:add_P3121(1)</a>
function add_P1607(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P1607')){coreFrame.load_add(d,type,'P1607','205/50VR16 KUMHO KH15 86V','1.00','2055016VR','0',0,'TD2,TD3','KH','','','KH',opt,sf,s,'');}else{setTimeout('add_P1607();',500);}}<b>205/50VR16 KUMHO KH15 86V
</b>
2055016VR
£44.00dw(qandi(['P1607','0.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P1607()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P1607()</a><a href="http://java%20script:add_P1607(1)" target="_blank">java script:add_P1607(1)</a>
function add_P1504(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P1504')){coreFrame.load_add(d,type,'P1504','205/50VR16 KUMHO 712 86V','1.00','2055016VR','0',0,'TD2,TD3','KH','','','KH',opt,sf,s,'');}else{setTimeout('add_P1504();',500);}}<b>205/50VR16 KUMHO 712 86V
</b>
2055016VR
£48.95dw(qandi(['P1504','0.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P1504()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P1504()</a><a href="http://java%20script:add_P1504(1)" target="_blank">java script:add_P1504(1)</a>
function add_P1503(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P1503')){coreFrame.load_add(d,type,'P1503','205/50VR16 KUMHO KH11 86V','1.00','2055016VR','0',0,'TD2,TD3','KH','','','KH',opt,sf,s,'-1.00');}else{setTimeout('add_P1503();',500);}}<b>205/50VR16 KUMHO KH11 86V
</b>
2055016VR
£49.95dw(qandi(['P1503','-1.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P1503()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P1503()</a><a href="http://java%20script:add_P1503(1)" target="_blank">java script:add_P1503(1)</a>
function add_P1505(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P1505')){coreFrame.load_add(d,type,'P1505','205/50ZR16 KUMHO ECSTA 87W','1.00','2055016ZR','0',0,'TD2,TD3','KH','','','KH',opt,sf,s,'');}else{setTimeout('add_P1505();',500);}}<b>205/50ZR16 KUMHO ECSTA 87W
</b>
2055016ZR
£52.00dw(qandi(['P1505','0.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P1505()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P1505()</a><a href="http://java%20script:add_P1505(1)" target="_blank">java script:add_P1505(1)</a>
function add_P1507(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P1507')){coreFrame.load_add(d,type,'P1507','205/50ZR16 KUMHO KH11 87W','1.00','2055016ZR','0',0,'TD2,TD3','KH','','','KH',opt,sf,s,'-1.00');}else{setTimeout('add_P1507();',500);}}<b>205/50ZR16 KUMHO KH11 87W
</b>
2055016ZR
£52.00dw(qandi(['P1507','-1.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P1507()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P1507()</a><a href="http://java%20script:add_P1507(1)" target="_blank">java script:add_P1507(1)</a>
function add_P512(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P512')){coreFrame.load_add(d,type,'P512','205/50ZR16 MARSHAL MATRAC TX KU17 87W','1.00','2055016ZR','0',0,'TD2,TD3','KU17','','','MA',opt,sf,s,'-1.00');}else{setTimeout('add_P512();',500);}}<b>205/50ZR16 MARSHAL MATRAC TX KU17 87W
</b>
2055016ZR
£52.95dw(qandi(['P512','-1.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P512()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P512()</a><a href="http://java%20script:add_P512(1)" target="_blank">java script:add_P512(1)</a>
function add_P1506(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P1506')){coreFrame.load_add(d,type,'P1506','205/50ZR16 KUMHO 712 87W','1.00','2055016ZR','0',0,'TD2,TD3','KH','','','KH',opt,sf,s,'');}else{setTimeout('add_P1506();',500);}}<b>205/50ZR16 KUMHO 712 87W
</b>
2055016ZR
£53.00dw(qandi(['P1506','0.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P1506()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P1506()</a><a href="http://java%20script:add_P1506(1)" target="_blank">java script:add_P1506(1)</a>
function add_P684(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P684')){coreFrame.load_add(d,type,'P684','205/50VR16 FALKEN ZE512 87V','1.00','2055016VR','0',0,'TD2,TD3','512','','','FL',opt,sf,s,'-1.00');}else{setTimeout('add_P684();',500);}}<b>205/50VR16 FALKEN ZE512 87V
</b>
2055016VR
£54.00dw(qandi(['P684','-1.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P684()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P684()</a><a href="http://java%20script:add_P684(1)" target="_blank">java script:add_P684(1)</a>
function add_P1134(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P1134')){coreFrame.load_add(d,type,'P1134','205/50VR16 YOKOHAMA A680','1.00','2055016VR','0',0,'TD2,TD3','YO','','','YO',opt,sf,s,'');}else{setTimeout('add_P1134();',500);}}<b>205/50VR16 YOKOHAMA A680
</b>
2055016VR
£56.00dw(qandi(['P1134','0.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P1134()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P1134()</a><a href="http://java%20script:add_P1134(1)" target="_blank">java script:add_P1134(1)</a>
function add_P685(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P685')){coreFrame.load_add(d,type,'P685','205/50YR16 FALKEN FK451 87Y','1.00','2055016YR','0',0,'TD2,TD3','451','','','FL',opt,sf,s,'-1.00');}else{setTimeout('add_P685();',500);}}<b>205/50YR16 FALKEN FK451 87Y
</b>
2055016YR
£60.00dw(qandi(['P685','-1.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P685()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P685()</a><a href="http://java%20script:add_P685(1)" target="_blank">java script:add_P685(1)</a>
function add_P1296(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P1296')){coreFrame.load_add(d,type,'P1296','205/50VR16 FULDA EXELERO 87V','1.00','2055016VR','0',0,'TD2,TD3','EXELERO','','','FD',opt,sf,s,'0.00');}else{setTimeout('add_P1296();',500);}}<b>205/50VR16 FULDA EXELERO 87V
</b>
2055016VR
£66.00dw(qandi(['P1296','0.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P1296()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P1296()</a><a href="http://java%20script:add_P1296(1)" target="_blank">java script:add_P1296(1)</a>
function add_P1849(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P1849')){coreFrame.load_add(d,type,'P1849','205/50VR16 TOYO CF1 87V','1.00','2055016VR','0',0,'TD2,TD3','TO','','','TO',opt,sf,s,'');}else{setTimeout('add_P1849();',500);}}<b>205/50VR16 TOYO CF1 87V
</b>
2055016VR
£64.70dw(qandi(['P1849','0.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P1849()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P1849()</a><a href="http://java%20script:add_P1849(1)" target="_blank">java script:add_P1849(1)</a>
function add_P1297(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P1297')){coreFrame.load_add(d,type,'P1297','205/50WR16 FULDA EXELERO 87W FP','1.00','2055016YR','0',0,'TD2,TD3','EXELERO','','','FD',opt,sf,s,'0.00');}else{setTimeout('add_P1297();',500);}}<b>205/50WR16 FULDA EXELERO 87W FP
</b>
2055016YR
£68.00dw(qandi(['P1297','0.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P1297()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P1297()</a><a href="http://java%20script:add_P1297(1)" target="_blank">java script:add_P1297(1)</a>
function add_P854(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P854')){coreFrame.load_add(d,type,'P854','205/50VR16 AVON ZV3','1.00','2055016VR','0',0,'TD2,TD3','AV','','','AV',opt,sf,s,'0.00');}else{setTimeout('add_P854();',500);}}<b>205/50VR16 AVON ZV3
</b>
2055016VR
£66.00dw(qandi(['P854','0.00','0','','1'])); <a href="http://java%20script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd%5b'pconfirm'%5d));add_P854()" target="_blank">java script:sfAddPop(wm.url('pconfirm.html',topFrame.lmd['pconfirm']));add_P854()</a><a href="http://java%20script:add_P854(1)" target="_blank">java script:add_P854(1)</a>
function add_P855(type) { if(topFrame.coreLoaded&&wm&&wm.pProp('P855')){coreFrame.load_add(d,type,'P855','205/50WR16 AVON ZV3','1.00','2055016WR','0',0,'TD2,TD3','AV','','','AV',opt,sf,s,'0.00');}else{setTimeout('add_P855();',500);}}<b>205/50WR16 AVON ZV3
<b></b>
2055016WR
£70.00dw(qandi(['P855','0.00','0','','1']));
joeraz
by joeraz » Sat Aug 06, 2005 11:01 pm
hmm,, not as i thought it may of looked
joeraz
by joeraz » Sat Aug 06, 2005 11:03 pm
£54.00 205/50VR16 YOKOHAMA A680
are these directional?
joeraz
by Mark1 » Sat Aug 06, 2005 11:58 pm
I'd go for the Yokohama but I don't think they are directional.
<a href="http://www.revolution.eu.com/erol.html#1x0&&" target="_blank">http://www.revolution.eu.com/erol.html#1x0&&</a>
Club Treasurer
Club Treasurer
