Drilled &/or grooved discs
I have a feeling when she goes in for her MOT next week the its gona fail on the discs as they hav a rather large lip and scores round them but most places i look for discs list the same ones for all turbos 92-96,, im sure the post `95 cars had larger fronts.
any one confirm this and recommend good performing disc & pad package!
joeraz
Ive got the Black Diamond Combi discs and Greenstuff pads [img]/biggrin.gif[/img]
<!--QuoteBegin-CalibraTurbo99+--><div class='quotetop'>(CalibraTurbo99)</div><div class='quotemain'><!--QuoteEBegin-->Try LMF for a big 308mm conversion.
Very very well priced and you get all the stuff for around the same price as standard sized grooved/drilled discs and pads! [img]/wink.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
ok, i looked at there site and the upgrade package looks good but it baffles me
"Upgrade this kit with the awesome new Irmscher 308mm drilled & vented discs and/or EBC Greenstuff Pads - please select from the drop-down list below.
This kit is suitable only for the <!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->later<!--sizec--></span><!--/sizec--> Calibra V6 and Turbo models with 288mm front discs. It is NOT suitable for the <!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->early <!--sizec--></span><!--/sizec-->models with 284mm front discs.
17 inch minimum wheel diameter required. "
i am thinking that early models means youngest post `95
Just slap me
Just slap me
joeraz
