Clunking when on fall lock
by VivSE5 » Fri Aug 12, 2005 11:36 pm
As the title says, had new bushes, new arms? if thats what you call them,
so what else do I cross off the list?
And while we are at it, my handbrake doesnt always work,had it so called fixed at garage, but its gone again, got to leave it in first gear, lucky I was sat in it when the handbrake failed, went bang and off went my car!!!
Not going near the garage that did god knows what to it! you can hear grinding when you drive as well.
Any advice?
Got to find a decent garage round here, the one I used is now flats!!!
VivSE5
by Stupink » Sat Aug 13, 2005 8:56 am
rhythmical clonks linked to speed ur driving? CV joints on the driveshafts.
handbrake sounds a bit buggered, will need pulling apart to look i'd think, possibly one of the securing pins has shered off or similar if it went clonk and released on its own.. a new brake shoe fitting kit (few springs and bolts) should be all thats needed.
Time to buy a haynes? [img]/wink.gif[/img]
by VivSE5 » Mon Aug 15, 2005 2:47 pm
<!--QuoteBegin-Stupink+--><div class='quotetop'>(Stupink)</div><div class='quotemain'><!--QuoteEBegin-->rhythmical clonks linked to speed ur driving? CV joints on the driveshafts.
Time to buy a haynes? [img]/wink.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
I've had a Haynes for six years.
someone borried it at Billing a few years ago, and couldnt beleive how immaculate it was, as if never used [img]/wink.gif[/img]
VivSE5
by Stupink » Mon Aug 15, 2005 3:04 pm
Not even for a b+coke coaster? na.. u cant have used it for that it would have worn thru by now [img]/biggrin.gif[/img]
you can allways drop the car down here for bits and pieces, but I dunno where to reccomend up there in the north of the country [img]/tongue.gif[/img] for somewhere, I can't recall any other memebers in that area anymore to ask either :-S
by WillsToy » Mon Aug 15, 2005 3:16 pm
Best to pull you brakes apart does sound like the retaining pin and spring has popped off. Can cause some nasty scoring and knacker you brake shoes, not that they are used much.
Mine did this, used a washer tacked welded on the back plate with a sideway hole to enable the pin to slot through. Otherwise you may have to replace the backplate it the hole is knacked. Not a nice job.
pretty sure someone esle have this recently aswell.
Will
WillsToy
by Phil69 » Mon Aug 15, 2005 3:40 pm
I've had the pin go on mine before as well but the handbrake could also be down to the cable - it may have snapped.
As for the clonking, as already said, it could be your cv joint. Is it just a single clonk or is it continuous and/or speed related?
by VivSE5 » Mon Aug 15, 2005 3:48 pm
Just a single clonk, on full lock.
As for handbrake looks like im going to have to
find a nice machanic, as my other half is fed up with fixing my car!!!
MOT is due October as well, great innit [img]/smile.gif[/img]
Who gives a ****e tho, lurve driving her [img]/biggrin.gif[/img]
VivSE5
by Phil69 » Mon Aug 15, 2005 4:01 pm
Make sure everything is very tight. As I posted on someone elses thread, the wishbone bolts might not be tight enough or if its an aftermarket wishbone, the inserts may not have been fitted. Also get someone to check the steering rack bolts are tight - that could be moving!
by Stupink » Mon Aug 15, 2005 4:27 pm
maybe a top strutt mount or something then, get it up in the air and get them to check for play. check the trackrod ends over a pit on the ground, rest can be checked by wobbling the wheel by hand in the air. shoudlnt be any play in anything left/right or up/down. should be fairly easy to locate like that.
