Is my car lowered or standard?
Come on guys, slap a tape on it for me.
One of my rear springs has broken and woundered if you'd mind measuring from the top of the wheel arch to the ground for me front and back to see if mine are lowered.
I don't want to put standard springs on and find out that they should be lowerd. (may just go for a full set of -40 G-max anyway)
Thanks
Heather
Thanks
Heather
Heather
<!--QuoteBegin-Heather+--><div class='quotetop'>(Heather)</div><div class='quotemain'><!--QuoteEBegin-->One of my rear springs has broken and woundered if you'd mind measuring from the top of the wheel arch to the ground for me front and back to see if mine are lowered.
Thanks
Heather<!--QuoteEnd--></div><!--QuoteEEnd-->
I have two cally turbo spings, they are free if you want them...
email me <a href="mailto:yunisaz@hotmail.com">yunisaz@hotmail.com</a>
Thanks
EXCALLYT
I've only got the 8V (sorry thought I'd put that)
If the springs are standard I may just change the back ones but if I fit lower ones I will do them all.
I have been quoted £32.61 +VAT EACH for standard springs and £81 +VAT for a lower set from the same garage. Just worried about speed bumps etc. (Hubby had an Arkley lowered 3" and we couldn't go any ware where the lines were too thick on the road)
Heather
<!--QuoteBegin-Heather+--><div class='quotetop'>(Heather)</div><div class='quotemain'><!--QuoteEBegin-->Hubby had an Arkley lowered 3"<!--QuoteEnd--></div><!--QuoteEEnd-->Cool!
But I'm sure you will be OK with -35mm springs on you Cally. They are also a bit stiffer so don't 'dip' as much when going over the dreaded speed bumps [img]/smile.gif[/img]
daddycool
<!--QuoteBegin-knightonahorsie+--><div class='quotetop'>(knightonahorsie)</div><div class='quotemain'><!--QuoteEBegin-->I have a brand new boxed set of G-max springs for the 8v that I am asking £40 + postage (will let you know the postage cost)<!--QuoteEnd--></div><!--QuoteEEnd-->
now thats a bargain if ever I saw one [img]/wink.gif[/img]
