Suspension decisions!
I want to lower my cally....
Heard that Eibach Springs are the best to choose for a 25-30mm drop.
Just found some info on ESP design....
30mm drop in ride height (approximately)
Engineered and tested for optimum handling
Designed to work with standard shock absorbers
Progressive rate sports spring
No loss in ride quality
It's the bit about being designed to work with Standard shocks?
Is this a good idea? or should I be looking at uprating the shocks aswell?
No loss in ride qualityIt's the bit about being designed to work with Standard shocks?
midnightv6
