hand brake adjustment
by Robs-se » Fri Aug 26, 2005 9:40 pm
today i replaced the brake shoes. now when i apply the hand brake i get to the tenth notch on the handbrake lever before it actually works.
I followed the haynes manual but have gone wrong somewhere. Anyone any tips on where i probably went wrong. After loosening the adjuster yolk thing could i have not tightened it properly???
whoever put the spring under the adjuster wheel must have been ******* when he designed it. its a bugger to turn once the hub is on.
Also the spring, clip and cups that Vaux sold me according to their parts listing was different to the set up that was on the car... how bizzar
Rob
by Fraz » Fri Aug 26, 2005 11:13 pm
not sure been a while
but you need to adust the shoes so its a tight fit putting the drum on ..they should just lightly skiff whne you turn the drum..also make sure you have slackened the cable off a good bit before you do anything
you can also adust the shoes by the small holes in the back plate and once your happy you then take up slack on the cable
as for the retaining pins, they no longer do the ones that are fitted on the calibra which go in from the front of the back plate
you can get the newer ones on but it a bit of a job as you need to take the top two hub bolts off and bend the back plate a bit to get the pin behind the abs ring side of back plate
by Robs-se » Fri Aug 26, 2005 11:36 pm
Cheers Fraz will have another bash tomorrow
On all the cars i have had i've never got this right first time
Rob
by Robert_Dale » Sat Aug 27, 2005 7:43 am
Rob,
you sure you ain't tightened it the wrong way?
as fraz says put the shoes on adjusted to the hub so they are a tight fit, and just remember the right way to tighten them
Robert_Dale
by dj_smurph » Sat Aug 27, 2005 9:46 am
haynes say have the handbrake on 3 clicks tighten the adjuster until you get resistance put the handbrake on 6 clicks and the brakes should lock it took me about 2 hours to adjust the shoes after changing the discs nightmare job
dj_smurph
by Robs-se » Sun Aug 28, 2005 5:59 am
found the reason why i'm having problems.....
the cable on the drivers side doesn't move when applied
so the cable is stuck somewhere in the hosing probably
corroded somewhere. This could also sort the POPPING
i was getting when driving off. the brake lever was released
but felt very loose until the wheels moved breaking the bind
so to speak.
so a new cable i think.
The only disadvantage of the Calibra being so low is getting under it
to make the adjustments.
Rob
by Robs-se » Tue Sep 06, 2005 1:17 pm
handbrake sorted now. the passenger side was seized so not applying so
on goes the new cable and all adjusted. this also cured the POPPING i used to get when the handbrake was released. the lever use to go all loose until the car rolled forward and POPPED the handbrake off. I thought this was the ratchet. saved me looking at that now.
Car even flew through the MOT:D
Rob
by Toddy » Sun Sep 11, 2005 7:34 pm
Don't suppose you want to come round my house and sort mine:D
Toddy
by Robs-se » Tue Sep 13, 2005 1:16 pm
<!--QuoteBegin-Toddy+--><div class='quotetop'>(Toddy)</div><div class='quotemain'><!--QuoteEBegin-->Don't suppose you want to come round my house and sort mine
[img]/biggrin.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
Actually i never want to get under the car again. I got a bit stuck and panicked when i couldn't get out (what a sap eh:oops: ). When car was fully jacked up my chest was just rubbing the underside.
Rob
