cally turbo brakes
cally turbo brakes
by akuma » Wed Sep 14, 2005 7:52 pm
hey ya,
jus need the simplist of advise, exactly what tools do i need to remove and replace my front and rear brake discs and pads...and any other advise will be greatful. and that gap at the top of the suspension every one talks about, would that cause play? or is it jus a gap?
thanks
michael
akuma
by SukySaggi » Thu Sep 15, 2005 12:00 pm
Wheel brace, jack, philips and flat screw driver, punch, allen bolt socket set, copper grease, new discs and pads.
Don't know about the gap.
SukySaggi
by akuma » Fri Sep 16, 2005 6:44 am
cool thank you, i'll get on this as soon as possible. and tell you how it went.
akuma
by jaybv6 » Fri Sep 16, 2005 8:09 am
From what I recall the Allen key bolt is not one you will find in a standard socket set. I had a bit socket set (200 piece) and I still had to go out and buy the tool especially. When I get home later I'll look at the size.
jaybv6
by akuma » Sat Sep 17, 2005 8:03 pm
done it, all discs and pads and shoes changed....wasnt hard..... apart from finding the right discs was a real pain......next on the diy list, that damn gap at the top mount of my suspension, and the rear camber bushs......when i get the kit. any advise greatly appreciated.
thanks for your help.
michael
akuma
by Cheater2k » Sun Sep 18, 2005 1:37 am
Aye, the allan key isnt
youll need a 7mm allan key or socet.
Cheater2k
by Andy_Turbo4 » Sun Sep 18, 2005 9:28 am
or a drill if its mashed like they usally are:)
Andy_Turbo4
by akuma » Sun Sep 18, 2005 9:00 pm
mine were ok...well except one of the front bolts holding the disc was nearly rounded off. what do i have to do about the gap at the top of my suspension?
akuma
by akuma » Sun Sep 25, 2005 2:12 pm
no one has a solution? gap goes when jack the car up. there anything i could put between the rubber bit and its 'seat'?
thanks
akuma
by Cheater2k » Sun Sep 25, 2005 2:28 pm
its normal mate, nowt you can do really
Cheater2k
by akuma » Mon Sep 26, 2005 7:43 pm
its causing play, can hear it knocking when vehical gets light. plus wont it throw out my alignment and wear out my front tyres? theres gotta be some thing. i wont expect no for an answer.......what if i jus didnt use the bottom nut? thought the rubber plate jus sits on it.
akuma
