brake wearing
brake wearing
by Sam1986UK » Thu Sep 22, 2005 9:59 am
i got a mate who is a merchanic.
him and his dad (also a merchanic) swear by when braking to instead of keeping your foot on the brake until you stop,
they tap the brake on and off
they say that this reduces the brake wearing out as quick, because it aint being used for a long time or something to do with heating up, which means it dont wear as quick.
is this true or false? and if not, why?
Sam1986UK
by Dan Willis » Thu Sep 22, 2005 10:03 am
Eh? Well people swear by all sorts of stuff - and when you have an idea, it's hard to lose it.
Modern cars, with modern brakes are designed to be used a certain way. On/off braking ain't it. Besides, that's was ABS does (just more quickly). I'd worry that that sort of braking would be quite dangerous.
Dan
by SukySaggi » Thu Sep 22, 2005 10:53 am
Braking on and off would mean that the heat generated by the pad isn't transfered as much to the disk. Similiar in theory to when you stop you should not keep your foot on the brake when you have come to a stop.
SukySaggi
by Sam1986UK » Thu Sep 22, 2005 11:05 am
<!--QuoteBegin-SukySaggi+--><div class='quotetop'>(SukySaggi)</div><div class='quotemain'><!--QuoteEBegin-->Braking on and off would mean that the heat generated by the pad isn't transfered as much to the disk. Similiar in theory to when you stop you should not keep your foot on the brake when you have come to a stop.<!--QuoteEnd--></div><!--QuoteEEnd-->
so are you saying its a good or bad thing to do when slowing down?
Sam1986UK
by Dan Willis » Thu Sep 22, 2005 11:13 am
For longevity of your brakes, probably a good thing. For safety - bad. If I saw a car with it's brake lights going "on - off - on - off" I'd think there was something wrong.
Dan
by Sam1986UK » Thu Sep 22, 2005 11:32 am
which is good because atleast they wont & dont tail-gate you!
Sam1986UK
by Dan Willis » Thu Sep 22, 2005 11:49 am
Yeah there is that!
At the end of the day, it's down to you. It's the same as the "Use engine braking over the brakes" - what do you want to wear more? Hmm.
Dan
by Animal » Thu Sep 22, 2005 7:22 pm
<!--QuoteBegin-Sam1986UK+--><div class='quotetop'>(Sam1986UK)</div><div class='quotemain'><!--QuoteEBegin-->which is good because atleast they wont & dont tail-gate you!<!--QuoteEnd--></div><!--QuoteEEnd-->
People don't tail gate u if u use reverse to stop! lol....
by Stupink » Thu Sep 22, 2005 8:51 pm
Well if you brake for less time by going on/off, then you need to be braking harder when you do, which in turn will create just as much heat i'd immagine..
It sounds a very strange thing to be saying... unless they're on about *long* braking from high speed, in which case i've done it myself.. release the brakes after a bit when you feel them begin to fade and re apply them.. but thats no tapping on and off.
by wilkybar-kid » Thu Sep 22, 2005 9:29 pm
lol can not put a Calibra in reverse when it is going forwards, lol makes a nasty crunchey noise,i tend to through the transit in reverse when moving slowley to get around a 3 point turn quicker. just keep forgetting it is RWD and the Calibra aint!
As for the Brake pad wear, dont think it would make enuth diffrence to worry about, if on the off chance it does make a diffence...
wilkybar-kid
by kev208 » Thu Sep 22, 2005 9:55 pm
dont go as fast and you wont need to brake as much:)
kev208
by ealex » Thu Sep 22, 2005 10:40 pm
and no racing from stop light to stop light. no, not even if there's a quarter mile between them [img]/wink.gif[/img]
ealex
by dicky » Fri Sep 23, 2005 2:07 pm
Or... If ur sunroof aint buggerd like mign get a large bit of carboard and stick it outa the sunrood as this will act as an airbrake like them new mercs! Also looks very stylish.
dicky
by Sam1986UK » Fri Sep 23, 2005 2:29 pm
<!--QuoteBegin-dicky+--><div class='quotetop'>(dicky)</div><div class='quotemain'><!--QuoteEBegin-->Or... If ur sunroof aint buggerd like mign get a large bit of carboard and stick it outa the sunrood as this will act as an airbrake like them new mercs! Also looks very stylish.<!--QuoteEnd--></div><!--QuoteEEnd-->
i'll give that a try tonight! [img]/biggrin.gif[/img]
Sam1986UK
