Camber kit - ******* OFF!!
Right, aftering fitting a camber kit from CAV16, fitted it (took me 11 hours)
now, i had it set up on the 13/9 by demon tweeks, checked my rear tyres today, and there ****ed!!! and i mean really ****ed, it didnt even wear this quick on the normal bushes
Does anyone have any ideas?
Ive phoned tweeks, they told me to bring it in 8:30 tommrow morning, but how do i stand claiming new tyres from them?? i paid them to set the bushes up?? and by the looks of it, they havnt??
gggrrrr, i just dont have the money for 4 ****ing new tyres esp with a 15 days old son!!!!!
Cheater2k
how does it look to you? the camber on the wheels?
I've heard of improperly installed/setup bushes slip.. but i've never had a probelm with mine, but if they look a lot worse than just after they installed them its likely thats the problem [img]/sad.gif[/img]
did you get a geometry printout report from them after they installed them?
would it cost you much to get it verified at an independant garage? i'd be dubious to take it to the same place.. it might miraculously be "correct" if they think they're going to have to lump out for new tyres.. unless they're not that sort of place.. your best judgement.
<!--QuoteBegin-daddycool+--><div class='quotetop'>(daddycool)</div><div class='quotemain'><!--QuoteEBegin-->Get a new print out and take it from there! [img]/sad.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
yeah mate, its getting down tommrow morning, but if its right?? what do i do?? lol, what will that mean?? im on standard vaux (irmcher softstar) 17 inch wheels
Cheater2k
yeah , i know the brand name, but with a lot of these big firms thats all it is. doesnt allways mean much.
I think you stand a pretty good chance here though.. afterall it has to be a LONG way out to cause such damage in such a short ammount of time, its not like they're "real" drive wheels even.
That is ruling out bad tyres of course.. what make/model and size/pressure are you running them?
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->did you put new tyers on after they fitted the camber correction bushes or just used the ones you already had on<!--QuoteEnd--></div><!--QuoteEEnd-->
the ones i already had, but there were ok, not worn or anything
Cheater2k
<!--QuoteBegin-Stupink+--><div class='quotetop'>(Stupink)</div><div class='quotemain'><!--QuoteEBegin-->yeah , i know the brand name, but with a lot of these big firms thats all it is. doesnt allways mean much.
That is ruling out bad tyres of course.. what make/model and size/pressure are you running them?<!--QuoteEnd--></div><!--QuoteEEnd-->
Dunlop SP9000, not worn a huge ammount, look near enough new to be fair before the camber kit was fitted. i did the camber kit because it was out 3 degrees when i got the tracking done, thats why i ddi the rear camber to put it right [img]/sad.gif[/img]
running on irmcher softstars 17s. (215/40?45/17)
no in 500 miles the inside edge ONLY is to the thread??? on standard shocks, ircscher springs (soon to be koni shocks and apex springs)
Cheater2k
