Lowering springs
Lowering springs
I was wondering if anyone does springs any lower than a 60mm drop for the front. I've got -60's all round on mine at the mo and although the back looks perfect the front still looks a little high in the arches compared with the back and i wud like to lower the front a little more, something like 70mm or even 80mm if possible.
The_IceMan
-60 should be more than enough,
are they defo -60 all round, did you put them on yourself ?
reason I ask is a pal of mine bought a car a few years ago with a -60 drop all round.
one of the front springs snapped and when he took the fronts out they were -40 so the previous owner told him a bit of a porky !
Col
Yeh there def -60, fitted ordered and fitted em myself. i mean it is fairly low at the front, infact the car itself sits level i think. I just reckon it wud look better and handle slightly better if the front was slightly lower than the back. Its how ive had most of my cars set in the past and seems to do the trick
The_IceMan
