My Brakes are useless
I have a 96P 2.0L 16V and the brake light on the computer just wont go out. I recently put new brake pads on but the car feels like its not going to stop. The brakes once applied feel like they jump off the disc's. Help anyone!!
Eddington
No the mechanic informed me it should go out when he did the work. They have been done a while and they still scare me. I was doing a fair wack down a country road on my way to work as i got to a sharp bend and tried to slow down they just did'nt grip. I ended up going straight on into a hedge!!! took the car back to they mechanic but he said they were fine. are break problems common on calibras?
Eddington
1. your mechanic is wrong if the pad low light was on before the problem it will stay on until the sensors have been changed or the wires spliced if you dont fancy paying for the sensors.
2. When you have new pads you should take it easy for the first couple of hundred miles to allow them to bed in a bit.
3. Have you looked at the disks to check that they are ok.
4. take it to a different garage to have it checked.
Tim2001
Thanks
Thanks for the advice guys, To answer a couple of questions -
1. No the breaks don't feel spongy at all
2. The mechanic has said he bleed them and also said that the breaks on these cars were sh?t.
3. Discs look ok but they look very shiny almost like a mirror??
4 Why do you guys think when I break somtimes it feels like the pads have come off the discs??
Eddington
i tend to drive as fast as possible, then slow for the bend, then accelerate round the bend, doing this after a mile or two the brakes never worked well, i realy had to push hard, the brakes were smoking when i got were i was going
I got a cheapo set of drilled and grooves diskes and its sorted the problem
could be brake fade, try groved disks
ROG
Cheater2k
Thanks for all the help and advice fellas.
I don't usually drive that fast so I am at a loss. I,m taking it in today to get it sorted as I nearly met my maker last nite. The breaks are fairly new so I,m a little worried. The same guy who fitted them is having a look again he,s a mate and a really good mechanic
Eddington
<!--QuoteBegin-Andy_Turbo4+--><div class='quotetop'>(Andy_Turbo4)</div><div class='quotemain'><!--QuoteEBegin-->bit off the topic, but anyone tryed braking with there left foot, weird nearly went through the windscreen 200% better lol<!--QuoteEnd--></div><!--QuoteEEnd-->
lol
yeah i've done that. you don't seem to have the same control with the left foot.
[img]/smile.gif[/img]
lol
davefly76
