rear tilt
rear tilt
My car is tilting at the back to the right hand side and sits 10mm lower than the other
the spring looks ok with no damage
could it be the shocker that is causing it to sit lower??
its a bit of a nightmare as it means i scrape the bottom skirt when i go up my drive [img]/sad.gif[/img]
Robert_Dale
Is the car lowered??? ive found in the past on alot of cars ive owned that they dont sit level and usually sit slightly lower on the drivers side, mainly because there is always weight on that side when the car is driven. Try checking shocks, tyre pressures, spring sitting correctly etc though to be sure.
The_IceMan
