any1 no an easy way 2 fit antiroll bushes
by feckedcalibra » Tue Nov 01, 2005 5:36 pm
any 1 got a easy way of fittin the bushes be4 a try n get em on cuz ave got a short fuse LoL
cheers john
feckedcalibra
by Robert_Dale » Tue Nov 01, 2005 5:41 pm
John,
I'm the same mate, junior hacksaw is the only way i think!!!
when you get em off plenty of sandpaper and a bit of grease to slide them on easy enough!
Rob
Robert_Dale
by Blossey » Tue Nov 01, 2005 9:22 pm
My junior hacksaw only got me about half-way through, had to attack it with a full-size one and give it plenty of effort.
Good luck!
Blossey
by ealex » Tue Nov 01, 2005 10:06 pm
BURN 'EM OUT! [img]/smile.gif[/img] not sure on fitting. used some hidraulic thingy to push mine in
ealex
by dj_smurph » Sat Nov 05, 2005 11:39 am
hacksaw two parallel lines get a big flat blade screw driver open it up comes off nicely then use some silicone grease and slide them on if tight fit use a large socket and tap it on gently
dj_smurph
by ealex » Sat Nov 05, 2005 12:44 pm
did i mention you can BURN THEM?
ealex
by Toddy » Sun Nov 13, 2005 6:52 pm
Ar*e of a job, big hacksaw and a hammer:D
Toddy
by King Calibra » Sun Nov 13, 2005 6:54 pm
Angle Grinder!!! :twisted:
King Calibra
by Toddy » Sun Nov 13, 2005 6:55 pm
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Angle Grinder!!! :twisted:<!--QuoteEnd--></div><!--QuoteEEnd-->
Best idea yet:D
Toddy
by King Calibra » Mon Nov 14, 2005 12:37 am
<!--QuoteBegin-Toddy+--><div class='quotetop'>(Toddy)</div><div class='quotemain'><!--QuoteEBegin-->Best idea yet:D<!--QuoteEnd--></div><!--QuoteEEnd-->
That's what I plan on using.... I gotta do mine soon. Have the parts already, but it's just a matter of getting of my lazy *** and doing it.
I'm sure the clunking noise will get on my nerves soon enough.
King Calibra
by swchoi » Fri Nov 25, 2005 2:54 pm
Yeah, Like ealex said, just burn them. DOn't forget to cover brake pipes all that with metal sheet or something to protect.
swchoi
by Naz » Fri Nov 25, 2005 3:42 pm
What yr calibra do you have? the later ones are diff to the early type.
Early ones, you have to cut them off.
Later ones, its the whole eye bolt you replace and its very very easy.
Naz
by davefly76 » Fri Nov 25, 2005 4:27 pm
<!--QuoteBegin-feckedcalibra+--><div class='quotetop'>(feckedcalibra)</div><div class='quotemain'><!--QuoteEBegin-->any 1 got a easy way of fittin the bushes be4 a try n get em on cuz ave got a short fuse LoL
cheers john<!--QuoteEnd--></div><!--QuoteEEnd-->
there are a lot of helpful people on this site but please refrain from using text speak because it's bloody annoying and takes twice as long to read.
davefly76
by Naz » Fri Nov 25, 2005 4:39 pm
Lough Out Loud @ Dave [img]/tongue.gif[/img]
Naz
by Toddy » Tue Nov 29, 2005 2:34 pm
Done one of mine the other day in 30 mins (old type). Hacksaw right through it, smack a flat bladed screwdriver in the gap you have just made and lift the edges. It should now slide off, spray a bit of WD40 on the arm and get the new one into position (use another jack). Line up a bit off wood onto the face of the drop link and smack it with a hammer:icon_mrgr
No problems.
Toddy
