Wheel bearing?
Wheel bearing?
I'm getting a humming sound (and vibrations) through the cabin as I reach 50mph. Sounds like it's coming from the back passanger side somewhere. I'm thinking wheel bearing as when I go round a left hand corner the noise and vibrations die off.
Any ideas?
Any ideas?
Toddy
Jack the car up and grab wheel at top and bottom...see if there is any movment, also spin the wheel and see if you can hear any sounds (other than the brakes)
if you get movment have a good look at the bushes ..if nothing there its likley its you wheel bearing
not the job to DIY unless you have access to a press or large Vice ..but you can strip it down and take th hub to a garage and get them to press it in for you (cheaper that way)
