bloody koni kit
bloody koni kit
by Welsh_Andy » Sun Nov 27, 2005 12:28 am
slight prob which is getting on me ****,my springs are clunking when moving the steering whell at slow speed or stationary. is there anything i can do,or do i just have to bear with it, bearing in min having 18's on 205/35 dont help i guess
Welsh_Andy
by nigescalli » Sun Nov 27, 2005 1:20 am
had this prob with konis on a corsa and it turned out to be a knackered shock
nigescalli
by Welsh_Andy » Sun Nov 27, 2005 2:14 am
<!--QuoteBegin-nigescalli+--><div class='quotetop'>(nigescalli)</div><div class='quotemain'><!--QuoteEBegin-->had this prob with konis on a corsa and it turned out to be a knackered shock<!--QuoteEnd--></div><!--QuoteEEnd-->
bloody hope not tis less than a yr old:eek:
but has been quiet for ages,but hit a nasty pothole other day and now is worse than ever:sob:
Welsh_Andy
by se6 » Sun Nov 27, 2005 3:09 pm
I had similar on my car, wasnt Konis, but was the strut top worn. When the car was jacked up the whole leg would move quite a bit if you wiggled the wheel from top to bottom. I had a noise from the springs at slow speeds whilst turning.
by Welsh_Andy » Sun Nov 27, 2005 6:49 pm
<!--QuoteBegin-se6+--><div class='quotetop'>(se6)</div><div class='quotemain'><!--QuoteEBegin-->I had similar on my car, wasnt Konis, but was the strut top worn. When the car was jacked up the whole leg would move quite a bit if you wiggled the wheel from top to bottom. I had a noise from the springs at slow speeds whilst turning.<!--QuoteEnd--></div><!--QuoteEEnd-->
what is the fix to that?
Welsh_Andy
by Dan Willis » Sun Nov 27, 2005 7:29 pm
I had that too.. one spring wasn't sitting right (they actually have a notch) so it was popping in and out of it's tray. Easy mistake to make and was quickly rectified.
Dan
by se6 » Sun Nov 27, 2005 10:23 pm
I had to have a new strut top fitted, i let the garage fix it for me so not sure what was involved.
by Welsh_Andy » Mon Nov 28, 2005 3:46 pm
best i get it into a garage for a look c.
cheers guys
Welsh_Andy
by johnny_adidas » Mon Nov 28, 2005 4:01 pm
bloody potholes. i had mine running perfect after changing the tie rod ends. 1 or 2 big potholes later n its back grinding as bad as ever. the guy who did the tracking a hile back said the strut was damaged doh so maybe its as u suggest. bloody 18s. ill eventually get round to changing it.
johnny_adidas
by Welsh_Andy » Mon Nov 28, 2005 9:31 pm
never had any probs with suspension while running 17's but since 18's have had nothing but probs,when u hit a polehole,apart from breaking your back, u think the strut will come through :eek:
Welsh_Andy
by AndiSe5 » Mon Nov 28, 2005 11:18 pm
I have just had this problem after i fitted my konis, at low speed i got creking but sounds like its just from the nr side.
To cold and wet to investigate at the moment.
AndiSe5
by Welsh_Andy » Tue Nov 29, 2005 5:53 am
<!--QuoteBegin-AndiSe5+--><div class='quotetop'>(AndiSe5)</div><div class='quotemain'><!--QuoteEBegin-->I have just had this problem after i fitted my konis, at low speed i got creking but sounds like its just from the nr side.
To cold and wet to investigate at the moment.<!--QuoteEnd--></div><!--QuoteEEnd-->
same side as me,although mines more a clunking
Welsh_Andy
by AndiSe5 » Tue Nov 29, 2005 10:40 pm
MMm yeah it could be discribed as a clunck / creak
AndiSe5
by cali steve » Wed Jan 11, 2006 5:42 pm
has anyone rectified this problem yet, ive just fitted Koni adjustables and am getting the same problem, can be really load at times, just had them apart to see if i could see a problem but everything looks ok, the wheel does move forward though when its jacked up as if the whole strut wasnt seated correctly ?! doing my head in now and its gotta be really load outside the car ?!
cali steve
by johnny_adidas » Wed Jan 11, 2006 5:51 pm
ive rectified it, turned the gain on the 2 subs up!!!!!
on a more serious note that, what can happen if the strut is damaged?
johnny_adidas
