Quick camber question
Hello,
My rear tyres are nearly bald in the inner edge, Only had them for about 4500 miles so far..
I have been reading posts about adjustable camber bushes, and find them to be expensive for what they do and was thinking......:headphone ....The SE 5 and DTM models came in standard form -25mm lower than regular models, So surely a set of bushes for these cars would be a lot cheaper, As my car is only lowered by -35mm at the rear on EIBACH springs, The 10mm difference would would not make that much of a difference.
Am I correct with my line of thinking or totaly off my rocker?
What do you think? Or what have youz done to correct your camber?
Cheers Mac.
Cheers Mac.
Mac
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->The SE 5 and DTM models came in standard form -25mm lower than regular models, So surely a set of bushes for these cars would be a lot cheaper,<!--QuoteEnd--></div><!--QuoteEEnd-->The bushes for these cars were made by Irmscher and are available through Vauxhall. Not cheap (£70 plus), hard to fit and make three fifths of f**k all difference. Better off getting the rear camber adjustment kit. More expensive but at least they do exactly what they say on the box.. or so I've heard.
MickM
