abs speed sensor
abs speed sensor
by houston » Sat Dec 17, 2005 3:32 am
i did the brake test and got code 43, which i assume is a wiring fault for the o.s speed sensor, does anyone have any guides on fault finding for these, what i should be looking for, etc...
any help will be a great help as this is the only thing stopping me gettin it in for an mot now, cant be long now tilll its on the road!!!!
houston
by Stupink » Sat Dec 17, 2005 10:15 am
43 RH Front Speed Sensor ( Resistance & Connections )
What you need to do is follow the sensor back to the connection plug, undo it there, then do the same the other side, and with a multimeter check the resistance across the plug going to the actual sensor. the good side should show you roughly what to expect from the dodgy one, if they're similar you know its a wiring fault from the other connector back to the abs unit(unlikely), if they're not similar or there is nothing at all to the sensor you know you need a new sensor.. I seem to recall that some people have had issues with the wire snapping near the connector, so it could be worth chopping off a couple of inches and testing it ther,e you might get away just putting a new plug on it. but i expect its knackered.
