hello help needed
hello help needed
by ben 16v » Sun Jan 08, 2006 1:04 pm
i have a been using tyres up at a fast rate on the back due to severe camber angles how can i but it right thanks
ben 16v
by robs_cal » Sun Jan 08, 2006 1:38 pm
I assume the car has been lowered?
Also what size wheel/tyres you got on the back?
robs_cal
by Tim2001 » Sun Jan 08, 2006 1:50 pm
Camber correction bushes do a search on here or i believe you can buy them from vauxhall amongst others
Tim2001
by davefly76 » Sun Jan 08, 2006 4:11 pm
<!--QuoteBegin-Tim2001+--><div class='quotetop'>(Tim2001)</div><div class='quotemain'><!--QuoteEBegin-->i believe you can buy them from vauxhall amongst others<!--QuoteEnd--></div><!--QuoteEEnd-->
i've never heard of vx selling them???
i believe the camber correction bushes just replace the originals but how does this change the camber angle?
[img]/smile.gif[/img]
davefly76
by Stupink » Sun Jan 08, 2006 4:15 pm
Bolt holes are not central in the bushes.
Vauxhall sell non-ajustable irmsher ones for use in the dtm's or le's or whatever it is, the turbo special edition thats lowered as std.
by davefly76 » Mon Jan 09, 2006 9:45 am
<!--QuoteBegin-Stupink+--><div class='quotetop'>(Stupink)</div><div class='quotemain'><!--QuoteEBegin-->Bolt holes are not central in the bushes.
Vauxhall sell non-ajustable irmsher ones for use in the dtm's or le's or whatever it is, the turbo special edition thats lowered as std.<!--QuoteEnd--></div><!--QuoteEEnd-->
aha! clubcalibra's mountain of information strikes again!
cheers for that, i may give irmscher a ring today
davefly76
by davefly76 » Mon Jan 09, 2006 5:49 pm
ok. i rang irmscher today and they said they only supply the bushes for the 4x4 (i.e turbo's) but aren't they all the same?
is it this bush (item 2) which is replaced?
<a href="http://img470.imageshack.us/my.php?image=rearbush1yo.jpg" target="_blank">Image</a>
davefly76
by Cheater2k » Tue Jan 24, 2006 10:46 pm
aye, i have the fully adjustable toe anc camber ones on mine, no problems at all with the rear, just the front now [img]/sad.gif[/img]
Cheater2k
