air in pas system?
air in pas system?
by complaints69 » Sun Jan 29, 2006 10:51 pm
Have read through some posts about pas as mine is whining away good and propper.
I don't drive it much (only at weekends really) and today i heard this noise.
I read on one post that air could be causing this noise. How does the air get in there?
I done the whoosh earlier, and the fluid level was on the min mark, the engine was warmed up after a 2 mile drive, does that mean that the pas fluid is warm too? I am thinking no, but maybe wrong.
I did notice too that there were quite a few small air bubbles floating on the top of the fluid when checking the level.
What are other peoples experiences with this subject?
Calibra Turbo LE 28
by Rusty_CallyT » Sun Jan 29, 2006 10:58 pm
bleed the system and make sure theres enough fluid in there:
guide here: <a href="http://cav16.co.uk/transfer/" target="_blank">http://cav16.co.uk/transfer/</a> <-- bleeding the hydraulic system
Rusty_CallyT
by Stupink » Sun Jan 29, 2006 11:11 pm
There are no min or max levels. just a cold and warm level, so if its been used a bit and is on the lower one you could top it up a bit. low level does make it whine, but it doesnt sound hugely low.
by Rusty_CallyT » Sun Jan 29, 2006 11:18 pm
mine whined a bit when i changed the fluid, had plenty in it, soon stopped tho once it had run a bit
Rusty_CallyT
by complaints69 » Sun Jan 29, 2006 11:48 pm
i will top it up a bit, what fluid do i need, where from, and what does it cost?
Calibra Turbo LE 28
by Stupink » Sun Jan 29, 2006 11:59 pm
dex2 PAS fluid 1L from vauxhall, ?under a tenner?
by Rusty_CallyT » Sun Jan 29, 2006 11:59 pm
dextron 2 or 3, halfords or anywhere else will sell it, price.. well whatevers on the shelf, dont think it will be more than £10/L tho
Rusty_CallyT
by complaints69 » Tue Jan 31, 2006 9:55 pm
got some dexron2 from vaux, £6.99.
The only querey i have is that it does say TRANSMISSION OIL on the label, and looks a bit red through the level indicator on the bottle. Is this definateley the right stuff?
Calibra Turbo LE 28
by Rusty_CallyT » Tue Jan 31, 2006 9:57 pm
PAS fluid and auto transmission fluid are the same thing
Rusty_CallyT
by complaints69 » Tue Jan 31, 2006 10:25 pm
nice one, cheers. hopefully i will be able to give it a go tomorrow.
Calibra Turbo LE 28
by complaints69 » Sun Feb 05, 2006 1:01 pm
well just topped it up in the end, the old fluid still looks ok, and it was too cold to stay out for too long. BRRRRRRR!
Calibra Turbo LE 28
