Strutbraces.
Strutbraces.
by TonyDTM » Thu Feb 02, 2006 12:34 am
Fitted my strutbrace today (from Strutbracer..where else)
anyone else had problems with the fit? It seems really tight round the suspension mounts until doing the bolts up which seems to pull it slightly out of position. I checked and marked it all out first before taking the drill to it, and although it looks nice and blingy i am not sure if it will be doing the intended job of counteracting some of the corner roll.
I fitted it at my works this evening and i didn't really notice any difference driving home even cornering quite hard. It is fitted very securely. No play on it at all.
Opinions please?
TonyDTM
by Fraz » Thu Feb 02, 2006 12:52 am
a picture would be good
by TonyDTM » Thu Feb 02, 2006 12:53 am
will post one when i get in tomorrow evening.
TonyDTM
by Fraz » Thu Feb 02, 2006 12:56 am
what sort of ends are on it ...does it have two rings that go right round the turrrets or just a bit that bolts onto it
by TonyDTM » Thu Feb 02, 2006 1:04 am
2 rings right round the turrets. I'll post a pic tomorrow evening m8, you can see it better than me trying to explain what may just be me being cautious.
nite nite lol
TonyDTM
by TonyDTM » Thu Feb 02, 2006 5:49 pm
See pix. The bolts are tight as they get, but it looks like its been pulled out of true. I think i might slacken the whole thing off and see if i can clamp it down somehow before trying them tight again.
TonyDTM
by Fraz » Thu Feb 02, 2006 7:39 pm
looks like my one (Sparco) , and never noticed any difference with mine...but there again never fitted it for that reason as they have their drawbacks
induces over-steer
by TonyDTM » Thu Feb 02, 2006 8:50 pm
Cheers Fraz, Since posting I have "re-set" it and tightened the outer most bolts first then the inners and it sits alot better now.
<!--coloro:red--><span style="color:red"><!--/coloro-->Just for anyone else reading this thread, if you intend fitting a sparco brace, either be prepared to drop the struts out or risk taking more of the skin off your knuckles. There is <!--sizeo:4--><span style="font-size:14pt;line-height:100%"><!--/sizeo--><!--coloro:navy--><span style="color:navy"><!--/coloro-->ZERO<!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--> space to work around the inner bolts. I ended up using an open end spanner with blue tack to hold the nut in place behind the coils, while trying to spin the bolt thru from the inside of the bay.<!--colorc--></span><!--/colorc-->
TonyDTM
by Fraz » Thu Feb 02, 2006 9:19 pm
oh i just used big self tapping bolts
by Fostersice17 » Fri Feb 03, 2006 6:06 pm
Hmm,i have the same sparco brace,have had it for 2 years and never got round to fitting it.Got all the chrome bolts ect,reading this post makes me wanna put it of for another 2 years!!!! I knew with bolts it was gonna be a tough job to without dropping the suspension.
Fostersice17
by Cheater2k » Sun Feb 05, 2006 12:15 pm
ill be fitting one to the tubbie when its ready for one, also after a rear one?? any ideas people?
Cheater2k
by Fraz » Sun Feb 05, 2006 1:01 pm
oh I have a rear one as well....called a towbar
by TonyDTM » Sun Feb 05, 2006 1:38 pm
somehow i dont think mine would look quite right with a towbar. BUT, it would make reversing into gaps to small for my car a breeze. I promise the day i fit a towbar to this will be the same day i fit roofbars and a big halfords luggage box on the top and go touring in france...c'est la vie...viva la cally !!!!!!!
TonyDTM
by Fraz » Sun Feb 05, 2006 1:56 pm
aha but you cant see mine
by TonyDTM » Sun Feb 05, 2006 2:02 pm
detachable balls. nah, my missus wouldn't let me lol
[img]/smile.gif[/img]
TonyDTM
