disc brakes temperature
Don't usually stick my fingers on hot surfaces for fun but I have been monitoring the temperature of my front and rear brakes as I think I could do with more braking power ( near misses ). Front vented ( diamond black ) rear solid oem. Even when abused the rear ones are only lukewarm, the front always very very hot I can only touch them for a sec.
It that the way it should be?
Molecule
I once thought my brakes were a bit sh*te so decided to give them a complete overhaul -
new discs front and back
new pads all round
new brake fluid
new handbrake shoes
new handbrake cable
black diamond brake hoses front and rear
and what a huge difference it made [img]/smile.gif[/img]
Check all your brake components and renew if necessary, that might eliminate any problems you have.
new pads all round
new brake fluid
new handbrake shoes
new handbrake cable
<!--QuoteBegin-RobbieV+--><div class='quotetop'>(RobbieV)</div><div class='quotemain'><!--QuoteEBegin-->I once thought my brakes were a bit sh*te so decided to give them a complete overhaul -
new pads all round
new brake fluid
new handbrake shoes
new handbrake cable
Check all your brake components and renew if necessary, that might eliminate any problems you have.<!--QuoteEnd--></div><!--QuoteEEnd-->
I have got all the bits to do exactly the same. [img]/smile.gif[/img] I just need to get new hoses. What do you recommend, it's not something I have bought before.
new pads all round
new brake fluid
new handbrake shoes
new handbrake cable
<!--QuoteBegin-Sg-1+--><div class='quotetop'>(Sg-1)</div><div class='quotemain'><!--QuoteEBegin-->I have got all the bits to do exactly the same. [img]/smile.gif[/img] I just need to get new hoses. What do you recommend, it's not something I have bought before.<!--QuoteEnd--></div><!--QuoteEEnd-->
Have a word with the (scary) man Fatz :icon_mrgr
